Find and replace material
7 REPLIES 7
Message 1 of 8
bthatcher
8725 Views, 7 Replies
Is it possible to replace one material with another through the entire model? Either in the interface or through the API? Thanks.
7 REPLIES 7
Message 2 of 8
Yes you can Cat Happy
You need to backup the main material (the one it will be replaced) by duplicating the material before replacing it ( I didn't mention this part in the video)
Copy the name of the material
Open new Project, Go to Manage-Materials (If ever you are afraid to override other material then instead of opening a new template then make a copy of your project with another name and the use it as the Temp file)
Select the new material you want to use it as replacement
Duplicate it or just rename it
Rename it with the name of your Main Material of your main project
Minimize the temporary opened project
On the main project, go to manage-Transfer project standards and just select Material from the temp opened project
So now the material is replaced, you could rename it without affecting anything
Here is a video to better visualize the solution
https://screencast.autodesk.com/main/details/503ef0a6-fa2b-4c5e-8244-71ccda4c2940
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 3 of 8
To supplement the response, we have been developing a plugin specifically for this purpose. Please find the Autodesk App store trial download link below:
https://apps.autodesk.com/RVT/en/Detail/Index?id=6565035931500761028&appLang=en&os=Win64
Message 4 of 8
Joe_Banks
in reply to: PolynineStudio
Just bought this app, it's just great.
Well done, big time saver.
Message 5 of 8
PolynineStudio
in reply to: Joe_Banks
Thank you! We're glad that you made good use of this tool. We developed this tool to save time and to be thorough with replacing materials, especially when receiving updated models with different standards on a weekly basis.
Message 6 of 8
Clever, thanks!
Message 7 of 8
Base12
This plug-in seems to no longer be available?
Message 8 of 8
Base12
in reply to: Alaaeldin_Alsahli
Great video, thanks!
