As the title suggests I'm trying to find a way of filtering the 'work in progress' section visibilities from a plan by view filters. The filter I use is 'Sheet Name' equal '<None>'. Then turning off visibility. It works when used in the Browser organisation filters but not in the view filter for the sheets.
Any suggestions, have I missed something?
I don't want to create a check box or dialogue box for the sheet as this will add to the required maintenance.
Thanks in advance,
Kevin
Solved by KevinFielding. Go to Solution.
OK,
After further investigation I have discovered it works when I select 'Sheet Name' does not contain, and then make sure the text box is blank, this allows for me to filter off the views not added on the sheets. For some reason the other method won't work.
By the way, I'm using this for presentation plans, key plans etc.
Hope this helps.
K
