Seems like such a simple thing...but--
Is it possible to Filter views ( and apply to view template ) for Text by Color?
We have some red text which we want to filter (off) in views for printing / issuing sheets, but have on for in-house review.
I could not find a way to set up a Filter for text notes, or color of text notes, etc.
Solved by SteveKStafford. Go to Solution.
Nope. One cannot target [most] Annotation Categories with View Filters. You also cannot change that particular Text Style to the color white, because it will still print as black. What you can do is temporarily change the font to the attached "GhostText.ttf" font (zipped), which is an entirely blank font I created. Of course, you would have to install this font on the computer that is going to be handling the printing. HTH.
Sorry Filters do not work on annotation, except View annotation like sections and elevations.
You can create a saved selection set of the text you'd like to be "non-printing". Select multiple elements and you should see a Selection panel where you can Save a selection set (true of the last few releases of Revit anyway, before that it is an extension from subscription). You can recall the selection set and then hide them for printing.
You can also use a Detail Item family because Filters do work on them. This means instead of placing red text, you place a Detail Item family that has "red text" formatted label that you can enter whatever comment is necessary. Then a Filter can use the Family Name to find them and turn them off in V/G.
Detail Items can also be schedule as of Revit 2014 and newer releases. This means you could schedule them to provide a summary of comments or remarks that have been placed in the model for action. Add a parameter for "Resolved" and users can indicate when the comment has been acted on.
Good reply, Steve.
I have usually been so "BIM" crazy that I usually had little if any text in a project--using Keynotes and Tags for just about everything.
But for this situation, the Detail Item Family sounds like a good solution.
I think adding Text Notes to Filters would be a good addition for future releases--albeit not very high priority.
Thanks!
A no print text convergence in the Revitverse, Luke wrote yesterday about a similar techniqe to keep track of issues. It's also like the Help icons that are in the sample project file (small-house one).
