I am trying to make my own filter in order to have a different color for each on eof the phases of my project.
for that i have tried in the past for the same project (but at an earlier stage) an dit worked this way: create a project parameter (text-phasing) and then use it as a filter rule. but now it not visible in the drop down menu or when pressing "..." and select it doesnt load.
the categories checked for the filter and the parameter are the same.
so, whats wrong? 😕
Thank you,
A.
If your project has phases, then organize the building elements in phases, and then use Phases' Graphic overrides. Not only it will give you the benefits of setting up colors easily, but other benefits such as schedules, different linetypes for different phases, separation of elements in different views, etc.
Does that "A" in the signature mean Angelica? 🙂
