I'm wondering if it is possible to filter/show only parameter values which are only applicable to that parameter. So no parameter values belonging to other parameters in a family.
This to avoid that users are selecting wrong values.
For example a door with several text parameters. See also the screendump.
Thanks in advance! Hans Hendriks.
Hans,
What you want is not possible (as far as I know). It is also on my wishlist for future versions.
There are some "workarounds" which I sometimes use. The type parameter lists all the items belonging to the types category. Some solutions I deploy are depending on circumstances:
-Remove Items that should not be part of the selection from the family.
-Move Items you do not want into the selection list to different categories.
-Create more than 1 family.
-Use type parameters and thus prevent user (not allowed) selections.
-Use a parameter field with a comment to explain use of parameter.
Above choice of method depends on type of user, experience user etcetera.
Louis
Please mention Revit version, especially when uploading Revit files.
