Filled Regions
3 REPLIES 3
182 Views, 3 Replies
Filled Regions
Sorry about being a pest today.
Titleblocks again. We have some "solid filled" areas that don't import
correctly from AutoCAD, so I'm redrawing them.
Only, the Filled Region doesn't have a "pick point" option (pick a point
inside an enclosed area to create the boundary - AutoCAD Hatch or
Boundary/BPoly command).
Is there any way to quickly create a filled region from existing lines and
arcs? The Pick arrow only let's me select one object at a time.
Reid M. Addis
Registered Architect
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
3 REPLIES 3
Pick one line and while hot Tab. Will pick all lines in chain.
"Reid M. Addis" wrote in message
news:5051504@discussion.autodesk.com...
Reid M. Addis
Granary Associates
Ph. 215-665-7056
did you get that? TAB while hovering over a line should pick the 'chain' of
lines, then click.
"Alek Sutulov" wrote in message
news:5051531@discussion.autodesk.com...
Reid M. Addis
Granary Associates
Ph. 215-665-7056
Or... Select one object. Hover over another further down the chain and hit
tab. This will select all in the chain from point a to point b.
"Scott Davis" wrote in message
news:5051827@discussion.autodesk.com...
lines, then click.
Reid M. Addis
Granary Associates
Ph. 215-665-7056
Rail Community
