I am having a bad day since I am sure I have found the solution to this problem before, but today its turning me grey!
I have an annotation tag which has a coloured title bar using a coloured region as a background to the title text. However having created a standard drafting detail in a 'Standard Details' project, using one of these annotation tags, when copied into a new project the colour is replaced by black losing the title text in the background.
Any ideas welcome please.
Try this:
click the tag > Edit Family >using TAB select the Flled Region backround colour >from Properties > Edit Type >Type Properties > Color -choose desired color- OK > Load back into project...I suppose it will work...
Your Name
The original family has the correct colour, it is when it is imported into a family that the colour changes.
Have tried all this and cannot find a reference to the filled region, or any filled region come to that. So no further forward thanks for trying
If you haven't already done so, try loading the family into a new project (using one of the default templates).
If the issue does not occur in the new project, then you know that it is related to a setting in your 'Standard Details' project. The following Revit Clinic post has information on tools to troubleshoot this situation:
Tools for Troubleshooting Unexpected Behavior in Revit
