Filled Region Hatch Origin
8 REPLIES 8
Message 1 of 9
dtdesign
12054 Views, 8 Replies
Hi all - does anyone know how to locate the 'starting point' for hatch patterns and filled regions?  I am laying the hatch in a bathroom and I want the pattern (which is representing tile) to start in a particular corner.
Thanks in advance for any suggestions..
Dave
8 REPLIES 8
Message 2 of 9
Alfredo_Medina
in reply to: dtdesign
Use the Align tool. Select a face of the wall, then and a line in the hatch pattern. Do it twice to align the corner of the walls with the corner of the hatch pattern.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 3 of 9
dtdesign
in reply to: Alfredo_Medina
Alfredo - I knew I could count on you to answer this...Thanks so much!  Revit is sometimes so easy that it is hard...
I appreciate the help!
Thanks!
-Dave
Message 4 of 9
anghelolivia
It seems I have the same problem. I tried to use the align tool but I can't select any of the hach line, in order to align with a reference.
Please help.
Thank you
Message 5 of 9
chrisplyler
in reply to: anghelolivia
It only works with model hatches, not with drafting hatches.
Message 6 of 9
anghelolivia
in reply to: chrisplyler
You were right, thank you !
Message 7 of 9
elena08TRH98
do you, by any chance, know how to hide the lines around the hatch?
thanks
Message 8 of 9
in reply to: elena08TRH98
Edit the filled region sketch boundary and change everything to <Invisible>.
Message 9 of 9
tnhtoo
Dave
To set up tile setting out, ie, to show tile starting point on plan.\
1. Use revit archi floor/ model for area.
2. change tile pattern in material browser/ surface pattern in graphic tab.
3. Adjust view setting, so that you can see tile lines on plan.
4. import dwg from acad of draw a ref line (cross line) which is tile starting point.
5. Move floor tile align with tile line to ref line.
6. Adjust floor area (double click floor tile).
7. Done!
Hope this will help you.
THET NAING HTOO
