Is there any way to control the layer and color of filled region when exporting from Revit to Cad Format?
I couldn't find the Filled region Category in Modify DWG/DXF Export Setup.
Thank for your support!
Solved by CoreyDaun. Go to Solution.
The Filled Regions export as Detail Items (and not as a Subcategory thereof). However, the actual color of the Filled Region will be preserved (via ByObject override) unless the "Export Layer Options:" pull-down (under the export setup dialog) is set to "Export All Properties BYLAYER, but do not export overrides". This will similarly affect other export elements, meaning that they will inherit the color "BYLAYER" rather than their actual color in Revit.
I am exporting a sheet with a scale bar on it. The scale bar is a family that has filled regions in it as well as text numbers. In Revit, the filled regions are filled with solid grey. When I export to AutoCAD using "Export category properties BYLAYER and overrides BYENTITY," the filled region inexplicably comes out black.
All the components of the scale bar family are exported to CAD on one layer, so if I change the screening of that layer to 50%, it screens the text as well, which we don't want.
Any ideas on how to fix this?
Yeah, I'm having exactly the same problem, I'm trying to export the filled region in grey in my sheet, although the layer in dwg becomes red. I tried to set it in the field title blocks in export settings, even though it doesn't work.
I don't understand why one cannot control the export layer of a filled region. Very annoying.
Autodesk, its 2022 now, is there a real solution ?
If not: does anybody know if there is a work around, like a plugin or a code?
