Hi Alfredo e Robert,
First, I would like to thank the feedbacks so far!
I believe the solution to measure blocks using schedules, with some adjustments, will be solve my problem.
But, besides counting the blocks, other masonry design requirements that must be attended are:
1. Resolve binding of walls;
2. Adjust modulations in the openings of doors and windows;
3. Extract floors plans for first and second courses;
4. Extract elevations.
Analyzing each requirement and based on what we discussed so far:
1. Until now, we treat the walls alone. But, I need to represent walls that are crossing a certain wall that I'm analyzing. At crossing points I must solve the modulation using the available fractions of my block family (in my case, not only two fractions). Can I solve this issue by just using fill patterns?
2. Another scenario is when I have openings for door and window. I need to resolve the modulation in the same way I mentioned in item 1. Again, Can I solve this issue by just using fill patterns?
3. I think I could use a drafiting fill pattern to represente the first course, but the second one? Can I associate two different fill patterns for each course in the same wall?
4. I think this point is the easiest, I can extract the elevations without problem. But there's only one point: In some situations I need to dimension the modulation. The problem is that the dimension commands does not recognize the faces of fill patterns. How Can I solve this issue?
Ari
