Revit Architecture
Revit Architecture
New Member
jordiversluis
Message 1 of 4 (241 Views)
Fill pattern doesn't rotates when rotating view on sheet
241 Views, 3 Replies
01-27-2014 04:26 AM
When I rotate a view on a sheet, the fill pattern of a filled region doesn't rotate with it.
Does anyone has an explanation? And how can I fix this?
Thanks!
Distinguished Contributor
Steve_Stafford
Message 2 of 4 (194 Views)
Re: Fill pattern doesn't rotates when rotating view on sheet
01-27-2014 06:25 PM in reply to: jordiversluis
If it is a Drafting Pattern then it won't, they maintain their orientation regardless of rotation. If it is a Model Pattern then it ought to rotating with the view.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
Product Support
klaus.schumann
Message 3 of 4 (154 Views)
01-31-2014 12:34 AM in reply to: Steve_Stafford
Hi Jordi, as per Steve's reply if you have a model pattern which fails to rotate, could you attach a sample model in which we can check the problem?
Klaus
Klaus Schumann
molson1
Message 4 of 4 (27 Views)
08-20-2014 03:03 PM in reply to: Steve_Stafford
Does anyone have any ideas, then, how to pattern an annotative family and have it maintain the angle of the pattern?
Announcements
Need installation help?
