Fill pattern doesn't rotates when rotating view on sheet
3 REPLIES 3
jordiversluis
925 Views, 3 Replies
When I rotate a view on a sheet, the fill pattern of a filled region doesn't rotate with it.
Does anyone has an explanation? And how can I fix this?
Thanks!
3 REPLIES 3
If it is a Drafting Pattern then it won't, they maintain their orientation regardless of rotation. If it is a Model Pattern then it ought to rotating with the view.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
Hi Jordi, as per Steve's reply if you have a model pattern which fails to rotate, could you attach a sample model in which we can check the problem?
Klaus
Klaus Schumann
Revit Specialist
marj.olson
in reply to: SteveKStafford
Does anyone have any ideas, then, how to pattern an annotative family and have it maintain the angle of the pattern?
Rail Community
