were is the a360 local file saved? I can't locate it. it's not in the default path for user files.
Solved by KyleB_Autodesk. Go to Solution.
Hi Scott,
Thanks for posting your question. If you are using A360 Drive Desktop Sync, then the default location will show up under File Explorer. If you are not using A360 Drive Desktop sync component, and uploading using a browser the local copy is where you are copying from.
With the A360 Drive Sync component, look at your system tray for the icon. Right click on itand select "Open Autodesk 360 drive" That will show you the local copy of the files that get synced to the A360 Drive WEB Site.
Hope this helps and thanks for posting your question.
when a file is uploaded to a360 with the new collaborate for revit it first makes you save a local copy before uploading to a360
After it is on a360 the local copy it had me save never changes and I find no local copy. It's like i'm working directly on the central in a360.
Scott,
The local data is contained in the Collaboration Cache located at "%LOCALAPPDATA%\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache" This is purposely tucked away in the user's machine because there's not really any need for them to every go there to access the data, which is also why we hash the file names.
What's the reason why you are wanting to learn more about this? We're glad to try and answer stuff for you.
Cheers,
Kyle
Got it. 2 things to note:
Cheers,
Kyle
