Hi:
It is possible to create a Parameter with the Filename? I have only found the FilePath parameter...
Thank you
Silvia
Not possible with the available features. Probably by using custom programming (API),
simple answer in NO.
workaround could be to use Project Name parameter.
you can change Project Name in Manage Tab/ Settings Panel.
