Revit Architecture
Revit Architecture
21 Kudos
Post 11 of 13
Re: File Path Label - Titleblock
04-22-2012 09:26 PM in reply to: damo3
glad to know that you are able to reach desired result (but Autodesk should make it easy since it's a common requirement).
What I suggested was a easy to do work around and the next step to make it more intelligent could be the Shared Parameter which you have established.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
New Member
0 Kudos
Post 12 of 13
12-03-2012 06:10 AM in reply to: damo3
I have a similar problem with the File Path-Label.
I'm working on a shared project, so when printing a sheet the file label refers to my LOCAL file, with my initials and stuff added to it, instead of the CENTRAL file...!
Has anyone found a solution for this?
How can I redirect the file path label to point to the central file?
Member
0 Kudos
Post 13 of 13
06-13-2014 08:49 AM in reply to: damo3
Long Path Tool could be helpful in this situation.
