Fast way to make purlins and creating untypical roof layer
2 REPLIES 2
pasterski.k
4384 Views, 2 Replies
Hi guys, is there any fast way to make purlins like I marked on picture and later, how to creat roof layer? (some sheet, insulations and cover)
2 REPLIES 2
My way in doing these elements is using Roof by Extrusion and walls as helpers for beams and purlins :
  1. In a floor plane draw a vertical Reference Plane and name it , so to can be used as Work Plane
  2. In an Elevation View , paralel with the Reference Plane created in step 1 , make a Roof by Extrusion, drawing an open curved profile - adjust the length of the extrusion
  3. in the Level below the Roof , draw walls at a distance you want to place the curved beams ( you can use array in order to be able to play with the distances) - these walls are use only as helpers and can be later errased.
  4. attach the walls to Roof : select wall >Attach Top/Base - attach Top....
  5. create curved Beams: Structure > Beam (Load one if it is not already loaded)> activate 3D Snapping and Pick Lines  - pick on the curved intersection line between the wall and the roof underside
  6. as for the purlins , use Structure > Beam System > check in Properties >Costraints >3D and Pick Supports -pick the curved Beams made in step 5
  7. Finally you can errase the walls...
Constantin Stroescu
BIM Manager AGD
Your Name
Alisder.Brown
in reply to: pasterski.k
pasterski.k
The method Constantin shows is the best way, here is a screencast i done last month for the same issue.
https://screencast.autodesk.com/Main/Details/f253c591-bc63-4e6b-a2d4-da20667fc7b5
And as Constantin said, use a "Roof by Extrusion" for the curved roof, drawn in an Elevation/section
Hope this helsp
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Rail Community
