Hi guys, is there any fast way to make purlins like I marked on picture and later, how to creat roof layer? (some sheet, insulations and cover)
Solved by Alisder.Brown. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
My way in doing these elements is using Roof by Extrusion and walls as helpers for beams and purlins :
pasterski.k
The method Constantin shows is the best way, here is a screencast i done last month for the same issue.
https://screencast.autodesk.com/Main/Details/f253c591-bc63-4e6b-a2d4-da20667fc7b5
And as Constantin said, use a "Roof by Extrusion" for the curved roof, drawn in an Elevation/section
Hope this helsp
