How do get a fascia to suit the make up of the roof, the fascia is to small?
Or do i change the roof make up?
The make up of my external walls are all the same, but in 3d mode the block work is showing up on some of the walls how do i change this to show a plaster finish??
Had the same problem fasica only imported in certain szes and make-ups.
I changed the make-up of the roof to suit the fasica.
As for the wall make-up if you highlight the wall the reverse key will be highlighted and if clicked
on it will change the wall from inside to outside and then move the wall back into its orginal postion.
