Another instance of something that should be so obvious yet Revit doesn't
get it. Anyways, I did find that I can just make an in-place roof family
with a horizontal extrusion generated from the side profile of the shed
roof. The fascia can just be a solid sweep around the extrusion.
"Aaron Rumple"
wrote in message
news:5186692@discussion.autodesk.com...
It doesn't work on the upper. The upper is always plumb cut. You'll have to
make an in-place void to cut the upper edge square.
"Jay" wrote in message
news:5186158@discussion.autodesk.com...
One more issue, I got the two-cut square option for rafter cut to work on
the lower eave, but not the upper.
