Family disappears along with annotations...
2 REPLIES 2
mike
261 Views, 2 Replies
I created a family, loaded it into a project. Created a section view, put that onto a sheet, annotated it. Saved the file. Closed the file. Reopened the file... All my dimensions have disappeared and I need to recreate the whole thing again. What would cause this to happen?... using Revit 2011.
2 REPLIES 2
in reply to: mike
You probably opened the file version that was saved
before you added the dimensions.
mike.zagorski
Turns out Revit turns off viewing of Masses... I turned that back on and voila, problem fixed 🙂
