Family dialog box does not open
1 REPLY 1
265 Views, 1 Reply
Recently, My revit does not load families.  The process I use is the following:
In the Build area of the home ribbon, I select the Component button.  I going to the Place component ribbon.  When I select Load Family form the Mode portion of the ribbon, the properties box pops up.  It is locked at this point and I cannot do anything but hit escape.  The program functions just fine in all other aspects.  I have used a vanilla project to see if the project I am working on is corrupted and I get the same results.
Has anyone had this issue?  My fellow user suggests reloading revit.
1 REPLY 1
Same here!!! Same exact problem!
