Is there a way to convert a wall based casework family to a floor based (free standing) casework family? Thanks and sorry for the noob question.
Solved by ryan.duell. Go to Solution.
When you specify a wall-based template, the hard-coded Host parameter is set > Wall. You cannot toggle this parameter unfortunately.
The best approach would be to create a new casework family and copy & paste the geometry from the wall-based family in. Then you can re-assign any constraints in the new family.
Thank you,
