Does anyone have wall based families for supply and return air registers (grills)?
I'd like to size length x heigh, have it cut the wall like a door or window, and have a fill pattern of horizontal lines at 50mm centres.
If no one has this, could you please tell me which type of Family Template I should use.
Thanks in advance.
N.
Solved by constantin.stroescu. Go to Solution.
I 'd use a Window Family..
Maybe the attached Family can be useful
Your Name
