I want to make perforated facade.
Do you have any ideas how to make it?
Thanks.
Solved by constantin.stroescu. Go to Solution.
The simplest way is to use Edit Profil in an Elevation View for linear walls
For curved walls , it could be used a Void Family applied as array
Your Name
if you want to use a pattern perforated , then a better solution is to use a Curtain Wall Family or Divide Surface in Mass ( in Place Mass or in Mass Editor).
If you want a pattern controlled by a mathematic function , then , it will be adequate to try to use Dynamo ...
Your Name
Finally, I used render material define like .cutout that it renders just white colour.
Thank you for your aswers.
