Why can't Revit make extrusion from polylines of imported DXF or DWG models? Revit 2013 update 3.
Why don't you draw this in Revit?
This, obviously, is just a small portion of a very complex, big drawing, and I need to import. After all, this question is feature related.
can you post the dxf or dwg files ?
All the test I made in Revit 2012 and Revit 2014 , work ...the extrude is ok - dwg and dxf ...I make the test as mass element and as Component -generic model...
I had some similar problems a while ago when importing some polylines composed of too many lines . In such a case , I think that, it's better to redraw the shapes ( as Alfredo suggests )
Your Name
Here is a test file - just a random spline drawing saved with Autocad Arch. 2013.
