This is done by using the Wall Reveal tool, with a profile that you create in a separate family file, using a profile template.
First, go to New > Family > choose a Profile template.
In that template, draw the polygonal shape that represents the plan view of the pier. Save the family, for example "pier.rfa", and clic on the Load into project.
Back in the project, switch to an elevation view, where you can see that wall.
Go to Home tab > Wall > Wall reveal ;
The sketch mode begins
Select Vertical
Clic on Element properties > Instance properties > edit type > profile > "pier.rfa" > ok to close.
Locate the pier on the wall's elevation.
Finish the sketch.
Clic on the pier to modify its height and/or location from the corner, by typing in the specific dimensions.
Alfredo Medina
www.planta1.com
Online training of
AutoCAD Revit Architecture Suite
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
