Revit Architecture
Active Contributor
0 Kudos
Post 1 of 6
Exterior Rendering Black?
764 Views, 5 Replies
08-24-2012 07:00 AM
First of All, my system is Windows 7 64bit with a 1gb graphics board and 8 gb ram.
The issue i have is 2 projects keep rendering black, The only thing i see that they have in common, they were both originally done in RAC 2011 then finished in RAC 2012. I have rendered them when using 2011 so i know that it could be done, now when i try to Render it goe to 2% and crashes leaving a black screen. anyone know a fix or why this is happening? I have not changed any settings nor did i add any type of new interior or exterior lighting.
Employee
26 Kudos
Post 2 of 6
Re: Exterior Rendering Black?
08-24-2012 08:41 AM in reply to: JOHNC17
Does the following post help?  Specifically clearing the temp folder. Let us know:
http://revitclinic.typepad.com/my_weblog/2011/02/troubleshooting-elements-that-disappear-when-render...
Ryan Duell
Revit Clinic
@revitclinic
Active Contributor
0 Kudos
Post 3 of 6
08-24-2012 09:01 AM in reply to: ryan.duell
I am using RAC 2012 Will the 2011 patch work in this version
Employee
26 Kudos
Post 4 of 6
08-24-2012 09:52 AM in reply to: JOHNC17
If using 2012 you do not need that specific hotfix.  The main item to check is closing Revit and clearing the %temp% folder then attempting to render again.
Ryan Duell
Revit Clinic
@revitclinic
Active Contributor
0 Kudos
Post 5 of 6
08-24-2012 09:54 AM in reply to: ryan.duell
I did and there is no change, screen renders black still
Active Contributor
0 Kudos
Post 6 of 6
08-24-2012 11:50 AM in reply to: JOHNC17
Checked updates and installed, still didn't work there either? It does seem some jobs can render and some not.
If i'm rendering an Exterior Perspective " Sun only"  would interior Lighting Effect this?
