I have placed wood beams and I-Joist on a floor plan. I can see both. I some cases (very few) I can extend the I-Joist over the beam to the far side face of the beam which is what I need to do. However, in most cases the I-Joist either extends or trims to the near face, which means the I-Joist is "floating and not sitting on the beam or the I-Joist extends or trims to the center line of the beam.
Is there a setting I need to set?
Marc
When you select the beam check in the properties and there is a place where you can enter "start extension" or "end extension". This will extend either end of the beam as far as you want.
