You can't set the options before doing a file link. So, I did a file link, did a reload and set those options, then Detached the file, and then linked the file again. When I did a reload the checkboxes were off. Can't get the checkboxes to stay on. Same issues with it losing the connection when the .max scene is reloaded.
I edited some settings in the filelink.ini, but that didn't seem to make a difference.
Regardless, this goes beyond materials, and we are losing all of the connection to the original DWG, as if I did a detach and re-attach from scratch. Modifiers, transforms, and materials are all gone.
Seems pretty important not to have fixed in max/VIZ after all this time. 😞
Jenni
