solid or surface model? or is the delay the same with both? What versions?
RAC08-dwg2007-max9-vray1.5?
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
wrote in message news:5631878@discussion.autodesk.com...
I am having issues with importing between revit and max. Eporting to 3D DWG
and then linking the DWG in max works fine, but as soon as I try to render
the VRay render window gives a 'transforming vertices' message that runs for
an inordinately long time. This process with a revit generated file takes
about 10 times longer than with a native Autocad file. Any ideas on how to
speed up this process?
We have tried to 'clean' the file in autocad (purge & audit, and even
pasting it into a clean drawing) but to no avail.
