I would like to export to dwg using my own layer standards. I see that you can load settings from file. it looks for a .txt file. how do I create a layer standard into a .txt file? is it something I need to do in CAD?
how do I create an "export layer file (*.txt)" based on my office standards layering system
Solved by LisaDrago. Go to Solution.
Hello ledge - the best way would be to go into the Modify DWG/DXF Export Settings dialog box and create a new export settings, and modify the information in there. You can change the layer names and color.
Yes this is a lot to go through but you do it once and it is set.
LD
Dear Lisa,
It's possible to save this configuration of Exports Settings and apply to another model of revit??
is a hard work to adapt this settings in each new model (if you have not created a previous template of course)
Thank you very much.
Regards!
You can do a transfer project standards from the Manage Tab>Settings panel>Transfer Project Standards
Make sure you have 2 projects open - (or a project and a template)
Start the Transfer Project Standards, a dialog box will open. You can uncheck everything and then check only the DWG/DXF Export Setup Settings. (see attached image)
This certainly would be good to have set in your company template.
LD
@Anonymous wrote:
Thank you, I was able to change the layer name and color, and on the lines tab, I told it to export grids as a center line, but the result was just changing the line itself and not the grid layer. Without going into a long explanation, It is important for us to have the grid layer itself be a center line. I don't understand why it's not an option in the layers tab.
Neither do I. If you do not want the exported grid lines to have a linetype other than Continuous, you could change the Export layer options from "Export category properties BYLAYER and override BYENTITY" to "Export all properties BYLAYER, but do not export overrides" or "Export all properties BYLAYER, and create new layers for overrides". Neither will give you exactly what you want, and either may have effects on other exported objects that are worse than having explicit linetypes on grid lines.
While getting a DWG/DXF Export Setup that matches your firm's AutoCAD standards as closely as possible makes life easier, to get a file that is as usable as a file created in AutoCAD requires post-Revit-export work, even if you use color-dependent plot styles, which is how Revit does the export (we use named plot styles). Our engineers and consultants also need to be able to control the way the exported file plots when attached to their files as an external reference via layer settings, so any hard-coded colors (for those using color-dependent plot styles) and lineweights cause problems. We could probably do a better job of mapping linetypes, but it seems the Revit export does not play nicely when LTSCALE is set to the value for plotting 1:1 and PSLTSCALE and MSLTSCALE are set to 1, which is how we work in AutoCAD.
We have created AutoCAD customizations to help automate the process of turning Revit exports into more-usable AutoCAD files, based on the premise that the Layer Name is done correctly, and everything else may need to be changed to our standards. Reworking the layers to get the right linetypes assigned is fairly easy; rooting out hard-coded colors and lineweights hiding in nested objects in block definitions not so much.
