No problems so far when I check the "Export views on sheets and links as external references" but when I do not check that box some dimension strings move ridiculously far away from the location as seen in Revit. This project is huge and we do not want XREFs for every single sheet (DWG file). Each view on the sheet is exported as a DWG block. I could modify each view with this problem, but it beats the point of exporting. Any assistance would be appreciated. Attached is a sample file.
I am also getting the same problem, and I thought it might have to do with it being a view that is referencing a linked view in another project file. Have you figured out the cause of this? It's brutal.
