Exporting Revit Model to Acrobat 3D
2 REPLIES 2
Terry Jordan - KJWW
726 Views, 2 Replies
Has anyone had any luck exporting a Revit 3D model directly to Acrobat 3D? I can't seem to get it to work.
I can export to AutoCAD and then to Acrobat 3D, but I lose all embedded Revit information. Any help would be appreciated.
Thanks!
Terry Jordan
2 REPLIES 2
in reply to: Terry Jordan - KJWW
The following is what Autodesk has published on Revit to PDF.
Printing PDF files
Published date: 2006-05-31
Applies to:
Autodesk® Revit® Building 9
Autodesk® Revit® Building 8.1
Issue
You want to print to a PDF file using Autodesk® Revit® Building, but the
option to create PDF files is not available, and you do not have a
third-party PDF writer application such as Adobe® Acrobat®.
Solution
You cannot printing directly to a PDF file with Revit®. However, you can
export the sheets to a DWG file and then use DWG TrueViewT 2007 to open the
DWG files and print them to PDF.
When printing in DWG TrueView 2007, use the DWG to PDF.pc3 printer to create
PDF files.
The latest version of DWG TrueView can be downloaded from:
http://www.autodesk.com/dwgtrueview
wrote in message
news:5215965@discussion.autodesk.com...
Thanks!
Terry Jordan
MichaelSchell8453
3D PDF for Revit® /w Acrobat XI Pro Suite
3DA provides rich and powerful solutions which can be used to automate repetitive tasks, extending core functionality of Revit in simulation, conceptual design, construction and building management, and much more. 3DA programs with any .NET compliant language including C#, and managed C++. Our unique approach to software development can provide extensive .NET code and documentation as a “one stop shop” for your companies first tool application all developed within the Revit API for Autodesk Revit Architecture/MEP/Structure.
http://splashurl.com/m8cbowf
or
 Autodesk Exchange App Store
 http://splashurl.com/mt2rfwt
