Exporting Revit files
4 REPLIES 4
bng918
295 Views, 4 Replies
Is it possible to export a Revit architecture 2009 file into Autodesk VIZ 2008?
If it is, how do you do it?
Any help would be appreciated
4 REPLIES 4
LisaDrago
in reply to: bng918
What file format are you looking for - I am not familiar with VIS.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
DarrenP
in reply to: LisaDrago
revit 2009 has the export to .fbx format try that first
if not try using .dwg format
DarrenP
DarrenP
in reply to: DarrenP
you may have to update the .fbx importer/exporter for viz: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=13091402
DarrenP
cbcarch
in reply to: bng918
That is some old software! Smiley Wink
If you upgrade to more recent versions , 3dsMaxDesign 2014-15 and Revit 2014-15, you can import .rvt right into 3dsMaxDesign.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
