Exported Text height
2 REPLIES 2
munsellh
279 Views, 2 Replies
When I exported my project to AutoCAD, the 1/8" text from Revit exported as 5/32". This happened with multiple different text sizes across the project. Has anyone else had this issue?
Other examples i have ssin in my project:
    3” is exporting as 3 9/16”
    1.5” is exporting as 1 25/32”
    1” is exporting as 1 3/16”
2 REPLIES 2
BIMAbhi
in reply to: munsellh
My Suggestion is:
Please check the Unit (inch) and Text treatment (Maintain functional fidelity) when you export the revit project. See the attached jpg.
Thanks & Regards
BIMAbhi
munsellh
in reply to: BIMAbhi
Units are set to inches and I have tried both options for text treatment. same results either way. Just curious have you had this issue and did that fix it for you?
HJM
Rail Community
