We're having a couple issues where when exporting DWFs from Revit a sheet or two are exported upside down from the rest. The strange thing is that this is only happening on that specific computer. Opening the same RVT on a different computer and exporting the same set is just fine. The initial time this happened, it didn't matter if you combined the sheets or kept them as separate files when exporting, the same sheet would be upside down in the set. The second time this happened it was on a different user machine and a different RVT file. It only occurs if you have them as a combined set. If you export as single sheets, they are are correctly orientated.
I haven't found any other instances where this is happening online.
This is running on Build: 20140606_1530(x64) Update Release 3
A silly issue, but an issue nonetheless. Any suggestions or others with this issue?
Just a follow up...This has now happened on two different computers and 3 different projects. 2 of the projects are part of the same department. The third project is from a totally different department using different templates.
