Exported as DWF from Revit 2014
4 REPLIES 4
ennujozlagam
692 Views, 4 Replies
Need Help.
Maybe you could help me with this problem when i open DWF file (exported from Revit 2014) into Autodesk design review 2013 i cannot see the file in
bigger screen space, anything to set?
Please see attached.
4 REPLIES 4
LisaDrago
in reply to: ennujozlagam
are you willing to send me the DWF?
lisa@kalblue.com
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
CoreyDaun
My Revit 2014 exported to .dwf and .dwfx, and my Design Review 2013 had no problems with those files. Can you attach your troublesome .dwf file here so we can try to open it in Design Review?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
ennujozlagam
in reply to: LisaDrago
i will send to you thru your email account, the project is confidential.thanks
ennujozlagam
in reply to: CoreyDaun
can i send you the file thru ur email? thanks
