I've been printing my Revit dwgs as pdfs....WYSIWYG. Don't know if that's an
option for you...there are free pdf writers on the web. I downloaded CutePDF
and it works well. Remember to go to your Sheet view to print (otherwise it
will try to print all open views)....and remember under Print Properties >
Advanced > to choose the option under TrueType Font: of "download as
softfont" and not "substitute with device font." Otherwise your text may run
wild.
David Ford
"drawler"
wrote in message
news:5300704@discussion.autodesk.com...
We need to export a set of working drawings from Revit into AutoCad. Is
there a standard plot setting in AutoCad, i.e. "acad.ctb" or
"AIAStandard.ctb", that will print/plot the drawings as if it were still in
Revit? We want to avoid adjusting the export settings withn Revit if
possible.
