Export to dwg
6 REPLIES 6
164 Views, 6 Replies
Export to dwg
Occasionally, when I export a sheet w/ multiple views to dwg, some of the
viewports come correctly, and some end up as rectangles in paper space, not
as viewports. How can I fix this?
6 REPLIES 6
Does it occur when there are many viewports? Are you sure they are
rectangles (ploylines) in ACAD? Reason I ask is ther is a system
variable in AutoCAD to control how many viewports will regenerate.
Maxactvp (I believe) is the system variable.
Other than that, I dont have a clue.
It usually happens when there are many views, don't have an exact figure,
but its more than 10. In the properties of the rectangles, they are called
"viewports", but I can't enter model space through them, the model doesn't
show up within them, etc.
"E L S" wrote in message
news:5062878@discussion.autodesk.com...
> not
Thanks, found that maxactvp! How can I get AutoCAD to max out the viewport
generation by default?
> not
I have not done much AutoCAD over the past three years (thanks Revit)
but IIRC, you can edit either the acad.lsp or acaddoc.lsp with the
following lines
;;begin code
(defun s::startup ()
(command "maxactvp" "64")
(princ "\nMAXACTVP sytem variable set to 64")
;;end code
I hope that helps
>>not
But, is there a way to control this from the revit side? I'm exporting
.dwgs to send to consultants, and I don't want to have to go into AutoCAD
for each file to adjust this before sending them out.
news:5063476@discussion.autodesk.com...
following lines
;;begin code
;;end code
I hope that helps
> viewport
>>not
Not to my knowledge.
Time to show your consultants a few AutoCAD tricks 🙂
> following lines
> ;;begin code
> ;;end code
> I hope that helps
>>viewport
>>>not
Rail Community
