Export to CAD
1 REPLY 1
wiencekaap
398 Views, 1 Reply
Export to CAD
Is there a way to export Revit to a STB based file. rather than the CTB file??
1 REPLY 1
Lance.Coffey
in reply to: wiencekaap
There is an open wishlist item for this option. If you would like to provide feedback on how this option would affect your workflow, you can use the following link to submit your feedback directly to our development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Currently, you can convert an exported DWG to use STB with the command CONVERTPSTYLES (in AutoCAD).
Lance Coffey
Technical Support Specialist
