Here is a weird one.
Currently when I "export to Cad format" "dwg" the resulting file is created with the wrong date and time.
I am exporting a view of a floor plan with the naming convension "Automatic - Short" and the "Export views on sheets and links as external references" turned off. When i proceed the resulting file has a date of June 25th 2013 at 4:46pm...today is October 16th , 2013 at 9:08am...according to my computer.
I've tried multiple times over the last couple weeks and have had the same result.
The weird part is if I switch to the "Automatic - Long (Specify prefix)" or "Manual (Specify name)" naming convension the date ends up being correct.
Why would this make a difference? Is there a way to fix this?
The fact that the naming convension doing this and not any of the other settings makes me think it is a Revit issue and not my computer.
Any thoughts?
Has this happened to anyone else?
Mike
Thank you for your post. In this case the file name/date/time is governed by Windows code. Does this happen for all users who log into your PC and test this? If you are the only user, please test creating a new windows user to log in and see how the results may compare. This may help identify the underling culprit if one presents itself within this test.
