Hello People
I have found that Revit 7 does not export the elevations as well as it did in earlier versions. For example, if I am using a wall with a surface pattern (eg Brick or Concrete pattern), some of the elevations have the pattern missing and some times this happens to the roof with a pattern. I find that I have to hatch these areas in AutoCAD to get by, I realise that I can use the sheet system in Revit, but at the moment I need to share these files with other consultants who only use AutoCAD.
Is anyone having the same problems or is there solution to this problem.
Richard
