Export Revit to CAD - family to block names
2 REPLIES 2
dglenn9000
2916 Views, 2 Replies
I am trying to figure out the best way to rename families that become cad blocks when the revit plan is exported to cad.
I need to follow another companies standard.  Lets say the  family  is called "Single Door" and the type is "flush 36x84 -DF01". When exported I end up with
Single Door - Flush 36x84_DF01 - View Name.
How do i get it so it is just named DF01. Which is the companies standard for that cad block?
is there a way to do this in Revit or will I have to write a lisp/script to do it in autocad?
2 REPLIES 2
Lance.Coffey
in reply to: dglenn9000
I have not found an option within Revit to change the block name used for families when exporting to DWG.
However, when searching online for lisp routines to change block names, I found several postings:
Multiple Block rename in sequence
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Multiple-Block-rename-in-sequence/td-...
Renaming a block using LISP
http://forums.augi.com/showthread.php?121288-Renaming-a-block-using-LISP
Rename multiple blocks
http://forums.augi.com/showthread.php?108553-Rename-multiple-blocks
Lance Coffey
Technical Support Specialist
AKingslayer
I have another issue with this.  When exporting a 3D view to AutoCAD for coordination with disciplines using AutoCAD 3D Models (CadWorx).  Any item that has been modified loses it's block name, and becomes a 3D solid.  This also overrides the colors used for creation of the REVIT model.
In my case it names the blocks this way (this is what I see in NavisWorks):
Item Name:  Family-Type-ID#-Viewname
Item Type:  3D solid
colors according to that in REVIT
For columns that have been attached, beams that have been coped, or had holes cut in them
Item Name:  .dwg file name
Item Type:  3D solid
colors according to layer export dialog
The problem I have with this, is the beam sizes and descriptions are lost to the next user (AutoCAD in particular, I know I could go directy from REVIT to Navisworks, but am forced to work with AutoCAD users for the time being)
