Using v9.1, the help file shows the following quote:
"If you are exporting to a DWG file, you can bind xrefs into the file by exporting multiple views into a single file. Select the Export each view or sheet as a single file option."
What I'm investigating is the possibility of exporting our model to a .dwg file that contains BOTH the floor and reflected ceiling plans. Using two separate base .dwgs will cause too many possibilities for error after distribution to our consultants. If we proceed with the method described in the help file, Revit creates separate base .dwgs for each view...
Is this possible and we're going about it incorrectly? Thanks.
