I assume you have AutoCAD since you are linking a dwg file into Revit, so
why not open it in CAD and insert it in? I don't know what you would do if
you don't have CAD though.
wrote in message news:5411877@discussion.autodesk.com...
Paul,
Your original post is a bit old, but did you ever find a solution to this.
I need the exact same thing to happen:
Export a sheet to dwg that is displaying a linked dwg. As of now, when I
export to dwg, pretty much the only thing I see are elements created in
revit and none of the original data from the linked dwg.
Appreciate any help - thanks
Boyd j.
