hi
i created new crosshead, pile and pilecap using default generic model family and then just change the catergory to my desired family.
my problem now is when i export my ifc,,, and upon checking it, they are now under generic models and not the family category i chose.
is this supposed to happen? kindly help, thanks.
using RVT13
tried: 2x3 and coordination view 2.0
tried to install exchange apps: ifc exporter for revit 2013 <-- still no change
tried to open and update my file in rvt2014 and do the export ifc there <-- still the same
whats the catch here?
im guessing you cannot use the generic model family and always use the correct family template?
http://www.revitcity.com/forums.php?action=viewthread&thread_id=31173
Thank you for your posting.
I can replicate this issue, and will discuss with QA on it. In case we need your further information, we would contact you directly.
Martijn,
I just saw your older video on AU web regarding IFC exporting.
One question real quick. Do you have the experience to export Grid lines out of revit through IFC?
Thanks.
