Revit Architecture
Member
K4rl33
Message 1 of 4 (420 Views)
Export DWG By Material
420 Views, 3 Replies
08-31-2013 04:28 AM
I'm walking around searching for a way to export my model in DWG, with layers subdivided by materials. Is it possible?
Thank you
Product Support
lanl
Message 2 of 4 (373 Views)
Re: Export DWG By Material
09-03-2013 01:18 AM in reply to: K4rl33
Hi K4rl33,
Unfortunately, you can't export the objects to different DWG layers based on the object material in Revit.
When exporting to DWG, you can set Layer Modifiers to create a rule how the objects of the same category will be exported to different dwg layers. But the rule available is limited currently.
For example, you can export the pipes, fittings, etc to different layers based on the system type, you can also export the walls to different layers based on the structural usage, function, etc. But it doesn't provide the material parameter as the rule.
You can check the post below to get detail information about layer rule setting when exporting to dwg.
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Import%2c_Export%2c_Layers/Export_P...
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
Member
K4rl33
Message 3 of 4 (342 Views)
09-14-2013 03:10 AM in reply to: lanl
Thanks for the support.
I think that this option would be great. Please consider it as a possible update for future versions of the program.
I would like to notice the absence of a "zoom to object" command, that would be great in a 3d visualization, to zoom and modify interior object (also working in more than a viewport) instead of creating 3d cameras. Please consider it for next version.
Thank you.
Product Support
lanl
Message 4 of 4 (321 Views)
09-16-2013 02:01 AM in reply to: K4rl33
Hi K4rl33,
Thanks for your feedback for our products. I would encourage you that report such wish list here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
You can use the form in the link to tell us what you think about our products, their features, and any improvements you would like to see. Then related people will read all the feedback recieved.
Thanks.
Lei Lan
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
