<Scott_Womack> wrote in messageArjun,
href="news:6135639@discussion.autodesk.com">news:6135639@discussion.autodesk.com...
There has been numerous threads on this over at AUGI.com. Too many to repeat
here, however there are a couple of threads on calculating the egress capacity
of a building for egress purposes. Back to door egress width: Creating a
parameter (possibly a Yes/no) check box parameter "Is this an Exit Door" would
allow you to schedule the door in a special door schedule, and use the door
with in a calculated schedule parameter to calculate egress with. You could
also do this within the family, and you could then create a special door tag
to show this width on the code plans. Travel distance is still a manual thing.
Revit is not intelligent enough to work out the distances between doors,
following the non-direct path needed.
A schedule without title, heading, border, heading, etc. would look like a tag. But this is a very old thread, so there maybe better solutions now. What exactly are you looking for?
Here's the image. I would also like the bottom to be a user defined "Max. allowable" instance parameter
