I have a project that has existing rooms that need to stay existing and new rooms. Is there a way to get both types of rooms into a Room Finish Schedule?
I can't seem to get both to coexist in one schedule. I would hate to place New room in the new construction phase to make this happen.
Thanks for the help.
Solved by kathryn.langan. Go to Solution.
Unfortunately it's not possible to have rooms from different phases show up in one schedule.
As a workaround, you could try exporting with DB Link or to ODBC, as the Rooms table should populate with all rooms, regardless of phase.
I hope this helps!
