Excel file into Revit Interface
4 REPLIES 4
BIMAbhi
892 Views, 4 Replies
Is ther any process to insert any excel file into Revit interface without the below mentioned option:
Open AutoACD > Insert the Excel by Table command > Save the AutoCAD file > Insert the .dwg file into Revit interface.
Thanks in advance!
Thanks & Regards
BIMAbhi
4 REPLIES 4
awes
in reply to: BIMAbhi
BIMAbhi
Thanks for your prompt response. We know about this tool and we have this with ourself. But we need to insert any external excel data into Revit interface which is not export from Revit by using the Excel2revit add-ins. So please suggest.
Thanks & Regards
BIMAbhi
TerryDotson
Take a look at Excel2DWG which works for your entire group, including links to Revit, Inventor and AutoCAD (including LT).
BIMAbhi
in reply to: awes
Thanks for your reply. It is very helful to us. Can you please confirm us where we can import the excel (mainly sheet/project view/ drafting view etc.)? If we import any excel with jpg (inserted), can we see the jpg in Revit.
Thanks again for your support.
Thanks & Regards
BIMAbhi
